if you have lets say 10 gallons of 91 pump fuel and add 2 gallons of 100...could you just use 94 octane instead ---average it out..my calculations are not correct i know...just using these numbers as an example
should a stock m1000 with no fuel controller and not running secondary injectors or extra fuel pump or regulator...... boost up to around 5 lbs and get richer as the rpms increase. this messes me up because im adding more air with the turbo and using stock injectors so i thought it should be leaning it out...or does my factory ecu compensate quite a bit...stock it has 43 lbs of fuel pressure...
