From a couple members pm's and madness who shared what they have been testing we pulled the weights and fired up the welder and in conjunction with a digital scale added weight slowly from 85 to 88.4 (88.4 worked so we did not have to grind). Heading out Friday to test with the hijacker installed in some deep snow, should be 3' plus in around 5000-7000'.
Piker
Stock: 8000 Max rpm stock with stage 2 barker, revy, 12-18 of fresh snow
You added over 3 grams to the weights with a welder? I hope they aren't brittle now. You wouldn't want one to break at 8000 rpm
I'am running 95grams @17 psi and still over reving. D@D tan spring and 44-40 helix. Need to mix gas on the long pulls the Octane light flashes.Also running the D@D barker can..........Just My 2 cents.
well if that is the case i would be getting rid of the 44\40 and the tan spring.the oct is going to go off form over rev .there maybe no oct issue just det could be pre det from no fuel or to much. with no a\f it well take some time to get fuel numbers dialed. with head studs and fuel 24 to 25 psi should be good hp gains. because stock it makes 18psi at around 7000feet to make this motor put out 180hp.
D&D Tan. not sure the spec on it.
I have Hindle exaust, Highjacker set at 18psi, 2.5" track, cold air intake, 60lbs of weight pulled off the sled and I weigh 300lbs with gear. No spring change, no helix change but I do have adj 85-95 weights. Started with 95 not shiffting really at all and 6800rpm. Currently have 85 grams and 7400rpm works better, still not shifting out great.
