Different cold air intakes
If you do a search on it you'll find a couple different threads on it. We've done a few different ways. Thru the hood (a la yami) which is super easy, just need a 2.5" 90, can, and a prefilter. More stealth look is to cut left factory intake open and duct straight to factory elbow or into a sealed space were the air filter used to be. Some fabrication required for that one. If you're handy with fiberglass there are lots of different ways to do it. On mine I ditched the headlight and made an intake plenum there that's ducted into the factory elbow. Whatever you decide you will likely need to duct your crank breather line into the factory elbow. With that you'll want an Donaldson oil roll over kit to stop oil from rolling into the turbo if the air filter is gone.
