m1100t clutching help
2012 m1100 turbo 162 with a straight pipe and magna force 86-102 weights running 86 grams right now. looking for info on what helix and primary and secondary spring i should use, ride 4-8000 in elavation. Also what would be a good belt to run other than the stock 082. any help would be appreicated. thanks
I have not done anything with the secondary in mine but the primary spring i got 130/330 and it works good. I had a boondocker 2.0 in it and i had to run lots of weight for some reason i had dalton weights and i had to run 102gr so it would not hit the reve limiter when i punched it.I am also using a dayco xtx belt i was only getting 250 mile on a cat belt and i have 400 on this one and have not blowen it up yet
