Hi everyone, I'm new to snowest, but was suggested this site for some help. I have a 2007 Arctic Cat M1000. It has the complete speedwerx kit; high compression head & pistons, dual pipes, re-flashed ecu (with powercommander 5 to richen mixture, egt too high), running on 110 octane fuel.
My question is this: The sled will start and run great out of the trailer, run it up and down the hills for hours, turning it off and starting it up again no problem. Then normally after a decent length ride, 30 minutes plus, I will shut the sled off b.s. for 10 minutes or better then go to start and it won't run.
First pull fires off the sled but it sounds like it's running on only one cylinder, and it bogs under throtle, then dies. From there on out it will not start. I tow it back to the trailer, put it up in the trailer and haul it home. 48 hours later i can go to start it and it fires right up and runs great. It's done this to me three times now, same symptoms each time.
I have checked compression 150-160 psi each cylinder. Fuel pressure is about 50 psi and consistant. I have no idea where this problem is coming from. I am trying to get the sled ready for a trip up to Canada but with these problems I don't trust it. Any suggestions, ideas, or shots in the dark would be incredibly appreciated.
Thanks in advance for everyones help.
