D
Well, I'm back again, needing help with my 2008 M1000 162". I have a weird electrical glitch that i need help tracking down. Here are my symptoms:
I'm sure some of you will say its a bad ground, however, after installing the brand new engine last week, I took it to the dealer to check everything out (especially the grounds) and they said it all looked good. Now I guess I'm leaning towards a CCU going bad? The sled runs fine other than the above mentioned problems. Anyone else experience this? I really got a lemon of a sled, but I'm bound and determined to make it a winner! Help me please![Face Icon Small Happy :face-icon-small-hap :face-icon-small-hap](https://www.snowest.com/forum/images/smilies/old/face-icon-small-happy.gif)
- Old speedometer/gauge (non snowpro) was on the fritz w/ lots of moisture in it so I ordered a new up to date one. Put it on and started the sled only to find its going bananas too and working intermittently, just like the old one
- Low beam headlights do not work.. High beams work fine, but the low beam/running lights don't work. No idea on the tail light because I don't have one
- Has a funny idle problem. I thought i had the idle dialed in a 1900-2000 rpm where its happy and not shaking by using the set screw adjuster. However, when I go ride and it gets hot and I stop and let it idle, it will hang out around 2000-3000 rpms for about 5-10 seconds, then it will go to my set point 1800-2000 rpm, and then after 20-30 seconds or more, it will kick down to 1350-1550 and do its earth shaking dance. I never does it for me in the lot or at home, its only when I'm riding it and its just been run hard
