Checking the compression is the first thing i would do when buying a used sled, sounds a bit low but like others have said guages do make a difference as well as method of testing. I would warm it up good, shut the power off, pull a plug on the cylinder you are not testing (makes it way easier to pull over), ground it properly, then install tester into the one you are testing and ground that plug properly, then pull it over till it stops building (give it 4 or 5 good pulls), as long as you are within 10 lbs of each other you should be ok but even at 6 lbs difference i would keep an eye on it once and a while. JMT
