M1000 2009 , pure logic programming
Hi, my m1000 run bad , i have , Y-pipe D&D , highflow intake Speedwerx , and pure logic fuel controller and i doesn't found a perfect set-up for the controller .
i ride at 0-3000 ft altitude
my set-up is : green 1-2
yellow 2-3
red 2-3
blue green 0
blue yellow 0
blue red 4
when i ride at 30 mph and i snap the trottle wide open the sled run super good , maybe when i do a u-turn for go back , the motor buck and run bad , ....
thank you
pascal:confused:
More information needed, what is it doing exactly? You haven't provided much info. low end bog? top end bog, Sputter?
Then we might be able to help.
sorry i'm french , but my english is not very good lolll , in low end it bug like when the engine is cold. so when I rode 50km/h i put the trottle wide open , and it run super good ,
the **** is just when I do a u-turn to go back and when I accelerate the engine « braaa brrrrraaa » same like a engine tooo rich in Gaz , i don't understand all , because i have trying many set-up .
You need to know where your fuel pressure is. I use the Attitude box ( like the Pure Logic ) The version I have will only pull 3% of fuel max across the board. I could not get mine to run well untill I dialed down my fuel pressure. Once you get your fuel pressure where it needs to be then you can tune. I would also pay attention to Mode 6. You may have full throttle fuel comming in too soon. I doubt this is the main problem, but I did have a bog problem with mine in this mode trying to time it with the power-valves opening.
I have a home made one so any will work. but You may want to check it with another gauge. all gauges are slightly different.
As for the bog if it runs better could and bogs when hot its probably a lean bog and you need more fuel. the computer runs rich until warm. I think rckymntchris is prob right on this one though.
ok I see then I'll buy a pressure gauge and how many psi I need to put ?
and if you have any ajustement for the control box
you can make me'll appreciate its !
Thank you:D
There's nothing wrong with your fuel control box, keep it.
Where is your fuel pressure right now?
Mine is set at 41#, and I have the green, yellow, and red all set at 1......no bogs anywhere.
Guy I bought the sled from said he couldn't get rid of the loe end bog until he turned down the fuel pressure to 40-41# from about 44-45which was recommended.
I would start by changing your yellow to 2, then 1-2. Leave your 6 where it's at for now, but if your at full throttle, then let out, then back in real quick and you get a bog then I would try decreasing mode red/blue.
Just be careful when you are cutting back on the fuel and do it in the small increments, see how it runs. If it improves you know you are going in the right direction.
Hope this helps.
