thinking of building a rg m 1000 for next year. any ideas what a could expect for hp? also what are the pg kits making for hp?
Do you already own an M-1000, or will you be purchasing one to turbo? If you're going to be starting fresh, all-the-way-around, then I would consider riding style first and foremost in my decision process. If you are more of a tree banger, boondocker and a "sane man" hill climber kinda guy, then maybe a turbo 800 will be more to your liking. They are generally easier to tune, make good power, have some safety built in (DET sensor) and are generally easier to ride in the tight spots, while still providing plenty of grin power on the big hills. If, on the other hand you crave power/torque and love the "BIG STUFF" (chutes that have mountain goats quivering in their hoves) then a turbo 1000/1200 is for you.
Now with that said, I ran a pump/race gas kit M-1000 last year and found 8 to 9 pounds to be the sweet spot for me. I set it up to run clean down low....that took some work....and to run at 7600ish on a good pull. When all said and done, I was seeing approximately twice the track speed of a stock M-1000 with about the same running quality when off boost. This sled was the most fun of any sled I have ever owned when climbing bigger stuff in the deep powder. It also took the most work to get tuned and running right as well. This year I built a RG turbo M8.
This has been said many times by people with a lot more knowledge than I have...."turbos and pump gas don't belong in the same sentence." Can people make it work, Yes. Have they, yes. Are they on borrowed time, most likely. All it will take is a tank of bad pump gas or a time when you forget to turn down your boost when riding at lower elevations, and boom! Or more likely, you are getting tired of 5 pounds and want to push it just a little bit more on your nice new $20,000.00 dollor turbo M1000 and....BOOM!
To continue where Racinstation left off; M-1000 + 8/9 pounds of boost + 100LL =
Spend the the $$$$$ and get it right the first time. Then, continue to spend the $$$$$ to keep it right; that includes good fuel. JM2C
does the turbo size matter alot? ive been told anything smaller then a 3071 will lead to constant struggle with tuning and runability? is this true?
I am running a 162 1000 with CPC turbo been running 8 to 9lb on 50/50. sled has had its problems mostly attitude hose leaks but runs great now an a crap load of fun.
