low voltage going to fuel pump no start
recker65
2014 polaris pro r 800 switchback ,was riding about a mile and engine quiet ,towed home and put in the garage check the spark plugs and they have fire, then checked fuel pump and was not running ,did a back prob with a voltage meter and am only getting 5.3 volts when cranking it is electric start ,checked stator with ohm test checked ok ,i orderd a new one any way installed still no start ,so i that the voltage regulator. was bad orderd one and was sent the wrong one mine has a 4 pin plug and a 6 pin plug ,it`s like i`m running into a wall any help with this problem thanks.
I had a similar issue with my 20 850 khaos. Did a stator and voltage regulator with no fix. Ended up putting a flywheel on it and it fixed the problem. It would start up when the engine was cold but if you shut it off to get yourself unstuck it wouldn't start until the engine cooled down a bit. Super frustrating and it took me forever to figure it out.
I’ve had 3 Pros… This has happened on 2 of 3..
The white 4 wire plug coming from the stator melts and causes a poor connection; you wont be able to even get the connector apart as it will be melted together on the inside to the pins.
I had to remove the plug and solder in a new 4 wire trailer wire plug that you can buy at any auto parts store.
They work fine after..
