Can you guys give some possible causes for my stock '96 Summit 670 only getting up to 7200-ish RPM under load? Under no load it revs to 8400 easily. My HAC was replaced last season after it failed. I have had the primary and secondary clutches looked at by a good local shop, they said they looked fine wear wise, and the setup was correct for this altitude (4500, SLC Utah). The clickers are on 6, putting them back in the middle setting drops me about 400 RPM at WOT. I don't remember the compression numbers but the shop OK'd that too.
The sled had 4800 miles on it and I ride like an old man, so it hasn't been pounded much. I have owned it since 98 and only put 1200 miles on it. Motor pulls well down low, but gets anemic and wont get over 7200.
I'm going to change the bearings on the jackshaft and look for wear down the rest of the driveline, I think it's time for that. Belt is correct for the sled and new last year.
What else should I look for, after I pull and clean the carbs?
