2005 XC 700, stock compression was 125#, it's now 115# with the SLP cheater head (0-9000ft domes). They say the stock head is agressive in terms of compression, how can that be at 125#? Said with thier head the sled will start easier and be more reliable, but I don't care how hard the thing pulls over, it certainly isn't hard with 125#. I've seen some SKI-DOO sleds at 140# stock. SLP claims their head provides more HP due to a more efficient chamber design, which I can understand, but I feel that I'm leaving alot on the table with the reduced C.R. Seems like if I switched to the 9000+ft domes, C.R. would probably back closer to stock or a touch higher. I ride in lower MI, which is around 2000-3000ft. I added a SLP single, cheater head, and reeds at the same time and the sled runs strong, I guess I should do a back to back on the head to see if I gained anything. Anyone ever play around with the high elevation domes when running at low elevation? Or does anyone know what the cranking compression is with the high elevation domes?
