lost the snap
B
May 13, 2009
209
62
2013 xm 163
i have had to put my clutch on clicker 5 to get 8000 at 5000 ft level on the trail going in
and that last little shot at the end 7600 to 7900 rpm
any ideas as to what might be wrong
just had clutch primary and secondary gone through
4200 k and it doesn't stall going into reverse when cold or hot
  • 1 Star
Reactions: jcjc1
kanedog
Undefeated mountain clutching champ of the world.
3,118
3,923
I had a similar issue with my 16 800 Etec. This was the first year I didn’t drain the fuel and start fresh. I’ll do that and report back.
Mine has always ran good up till now. I wonder if the Etec’s are fuel sensitive.
  • Sad
Reactions: gun-driver
B
Sep 24, 2009
605
136
Yakima Wa
If it ran good before the clutch work, then I would go back into the clutches. Maybe someone installed the wrong spring? 4200 km? you might look at the pistons.
B
May 13, 2009
209
62
doesnt stall when putting in reverse right after cold start up
had the guy replace the springs
was gona ride out this season then change the pistons in the summer
  • Sad
Skidoox
35,195
68,088
Provo, UT
What is the engagement RPM and what is the max RPM? What colors are the primary spring and the secondary spring.
B
May 13, 2009
209
62
new belt about 200 k on it if
its not a clutch problem
swapped out with a new clutch and the same thing still having to
put it on clicker 5 to get it to rpm
kanedog
3,118
3,923
You answered one out four questions. Congrats.
The lack of effort on your part demonstrates the amount of help you will receive. Translation-It is only possible to get 25% of the total 100% available. Messsge-get off your ass and make things happen. Put in 25% and you will fail. Ask yo momma
  • Like
Reactions: kiliki
146ev
280
52
If you can answer what color springs you have in along with what pin what and ramp you’re running that will help us help you!
B
May 13, 2009
209
62
honestly i don't know the colors of the clutch spring
id of gone with what ever was stock for that year
clutch totally stock
and i believe he took out 2 grams
B
May 13, 2009
209
62
as it turn out i was watching a youtube sledding video
and the guy says when was the last time you checked your throttle cable
duh the one thing i haven't checked. had 1/8 of play (must of happened when adjustable riser installed replaced the cable and its back to normal.
i have my sled back now. Yehhaw
  • Like
Reactions: kanedog
