I put a new fix kit in my 2014 800 this fall at 1450 miles after I started to encounter some poor idling issues and lower compression on one side. One of the top rings gap ends was worn down, but I could see no evidence of it on the cylinder wall so that was a bit of a stumper.
The fix kit ran great for about 250 miles but I kept having poor idle issues. It would fire up and run when cold, but the after a few minutes the rpms would start dropping off and it would die. I could nurse it up to temp by staying on the throttle and it would run fine most of the day. Sometimes it needs a little gas to get going when starting. I checked compression at about 100 miles -135 on both sides, about 10 psi more than the stock setup.
I started suspecting the TPS so I called up the dealer - 2 weeks out to check the TPS, so I bought the pig tails and power cord from Troy on Ebay and did a lot of research.
I powered the ECM using the battery from the wifes sled and using a Fluke 23 I found the voltage was 4.97, which I know is not the 4.99 - 5.01 but I figured it would be close enough. I could only get the 4.97 if I was only plugged into the ECM side. Once I plugged into the TPS as well the voltage dropped to 4.1 something. I backed the idle screw all the way out and saw .746. I loosened the TPS and set it at .70. I screwed the idle screw in to .93 and put everything back together. She fired right up and idled much better.
Today I lost the PTO cylinder about 5 miles from the parking lot. I didn't feel like it was running well from the get go, then she died. I'm at a loss. What could I have done to screw this up that bad? The MAG side plug looks normal. I haven't torn into it yet so I'm not sure what really happened. Is it possible I lost an injector? Maybe the throttle bodies were way out of sync? I figured I would try this simple reset before I dove all the way in to sync them.
Any ideas would be much appreciated.
On another note the products Troy has for sale are top notch:http://www.ebay.com/itm/Polaris-TPS...ash=item3f47dca047:g:qIAAAOSwe-FU72h~&vxp=mtr
