Shawnmcgr
I've had a suspension bolt back-out where the suspension bolts to drop brackets. The threads in the aluminum shaft are completely gone. The dealer is recommending either an insert to replace the threads or replacing the aluminum shaft.
I ride fairly hard; how do I make this bullet proof? Is there an after market cromoly shaft available anywhere? I don't like these aluminum threads at such a heavy stress point.
This is my 4th sled and I have never had to worry about suspension bolts backing out like I do on this sled. I've had both sides loosen up; I've got to carry a socket and wrench with me on rides to tighten them up. I've applied loctite to the side that still has threads...maybe that solves it.
Anyways, I'd appreciate hearing from guys that have had this problem and solved it. Should I just replace the aluminum shaft with a new one and loctite both sides or is there an aftermarket steel shaft available?
Thanks, McGreg.
Thanks, McGreg.
