looking for hot trail sled set up
I am looking for a point in the right direction on what kind of setup to put in my clutches i have a 99' 600 mxz
right now im running
200-320 primary spring
298 ramps
stock pins and arms
52/48 helix set at 18 pounds
stock gearing
298 ramps
stock pins and arms
stock gearing
My kit for that sled is the same..just I use 286 ramps (similar to 298)....its a solid combo...if you need my speed you need more HP...the dyno port pipe into the stock can works well...trail porting is worth about 10 hp...fresh pistons/rings wouldnt hurt either-BJ
