O
olymon
I'm currently putting a ultra motor in a gen II xc chassis. The problem I'm coming across is an oil tank that will fit in the space. I have a coolant bottle that I think will work the way I'm going to set it up. The stupid external thermometer on this motor through a twist in the routing.
I'd like to run the oil tank behind the stock ultra air box and between the steering post and the gas tank. I can't seem to find one thin enough. Most seem to have a bulge in them or a 90 degree turn on them somewhere.
Does anybody know of a tank that is roughly 1 1/2" wide about 5" or so tall and can be close to 12" long. Just a plain rectangular oil tank would be perfect. Hell, I even thought about using an old xlt coolant bottle I had lying around but I wasn't sure about how well it would seal at the top if you laid it over. I'd have to fill it pretty often too from an extra oil bottle carrier.
If you've seen an oil tank shaped like that let me know, I'd really appreciate it. Mounting it is a secondary thought, shouldn't be too hard.
