pointers, tried and true
I own and ride an 07 non boosted Apex. These are the
I have Boss seat,
under tunnel exhaust,
removed rack,
Removed all foam under hood & side panels. (this seems stupid but foam is heavy when soaked with water)
2" pivot ROX riser
Gold finger lefty (must have on hard snow off camber side hills)
2 wheel rear axle (carves noticeably easier)
Remove all wheels except rear two run ice scratchers, ( the Hyfax last longer without the wheels, wears more evenly)
19tooth gear, Clutching from Hartman (this is a MUST have and reverse!)
Relocate battery to seat pocket
Oil filter relocation kit
KMOD Gen 1 rear skid or Timbersled
Powerclaw or Camo Extreme track
Simmons Gen2 ski's....(must have)
Fox Float shock revalve/ conversion to the newer Float 2 valving, (this makes them much friendlier on the nose heavy Apex, allowing them to be stiffer but still give you a soft ride and stop the body role of this sled)
Better boards or a Rat sled tunnel see link, convertionhttp://www.brandtmotorsports.com/products/item/complete-widened-running-boards-with-rear-kick-up-bolt-on/
Hope this helps, once you've put a thousand miles on the sled in the powder you'll be comfortable enough with it to go any where with any of your buddies, non boosted I might add. If you have the above list or the main ones for function you'll even compete with other 2 smoke sleds assuming your an equivalent rider. cheers
