Installed a new Van Amburg tunnel on Nytro, have Timbersled suspension on Ice age rails. Have Front bolts or rear suspension bolted up, what procedure should I use to set up rear holes in drop brackets ?
i had the same question to bud at timber sled and was told 31 and 5/8 c ot c!this was on k-md drop bracket so should be the same?if in doubt phone them best customer support i have seen!
So 31 and 5/8 c to c that makes since... Now how about the up and down??
I would think you should have measured the stock tunnel mounting hole at center with the suspension at full extension, no pressure or downforce????
Or is there an easier way???
i bought a piece a metal strip and drilled 2 holes the proper distance apart. (31 5/8 sounds right) than bolted to the tunnel and drop bracket. Quick and easy. I guess it would be a little different for a VE tunnel since the drop brackets are incoporated into the tunnel
