List of factory 900 updates
N
Nolimits
New member
I have a friend that just bought an 05 900 RMK. He has a list of updates that were done to the sled on 12-10-04 and 3-22-05. Can anyone tell me what they were for. All he has are a bunch of numbers.
S-04-07
S-04-08
S-05-01
S-05-02
S-05-05
S-05-04
S-05-03
If you can tell us what these were, thank you!
S-04-07 NO IDEA
S-04-08 NO IDEA
S-05-01 A heat shield kit has been developed to protect underhood components fromexcessive heat. The kit contents include
a heat deflector with mounting hardware, and seven pre--cut pieces of heat resistant fabric tape. The instructions
included with the kit will illustrate where the deflector and pieces of tape are to be installed
S-05-02 A vent kit has been developed to reduce heat in the clutch / belt area and to enhance belt durability. The kit includes
one black--colored vent,mounting hardware and instructions for installing the vent on the clutch--side engine compartment
door.
S-05-05 An engine mount and torque stop update kit, PN 2203074, has been developed to enhance drive system efficiency, reduce
premature belt wear and improve drive and driven clutch alignment during operation.
The 2203074 update kit contains a torque stop limiter and washer designed to compliment the vehicle’s torque stop.
Because the vehicle was driven without the torque stop limiter and washer, the original torque stop and left--rear engine
mount may have been subjected to unnecessary wear and tear. Because of this, a new torque stop and left--rear engine
mount are also included in the kit. While the torque stop and left--rear engine mount are new parts, they are not new
designs.
S-05-04 Install foam seal, PN 5812749, around the headlight assembly. The foam seal will reduce the possibility for snow ingestion
into the air intake system while riding in deep powder conditions
S-05-03 Polaris Industries Inc. has determined that the handlebar wiring harness may be routed in a way that could disconnect
the engine stop switch and the throttle safety switch connector. Themost likely situation leading to this condition is when
the handlebars are in the Rider Selectt full--forward position (#7) and the handlebars are rotated fully to the right.
If this connector becomes unplugged, the engine stop and theETCswitches will no longer function. However, the keyed
ignition switch will continue to function and will shut down the vehicle when the key is in the OFF position.
The thumb warmer and right--side hand warmer could also become unplugged under these harness--routing conditions.
no sweat... replies in read above ;)
i also have the actual PDF files for each one if you need it, email me at guidoxpress@hotmail.com
you should also take the VIN# to your local polaris dealer and have them run it, there has been more updates on the 05 900 since these ones you listed...id say at least another 4-5 more
Thank you for that list.
S-04-07 & S-04-08 were the two that were done on 12-10-04, the others were done on 3-22-05. I will tell him to take the VIN to the dealer and check the rest of the updates. Thank you again!
Friend took VIN # to dealer today and found out there are a few updates that are still active for this sled, most haveing to do with the fuel tank and float if I remember right. Dealer is ordering the parts and taking care of it. Thank you guidoxpress for the advise about talking to dealer, without your advise he probably would not have talked to anyone about it.
By the way the one early update was a reflash and I can't remember the other one.
Thanks again!
