lights on rt 1000?
i tried to drop a cliff and it had a little problem with the landinig and stuck it straight up and down when i was getting out of my lil situation i noticed i was loosing gas and a lil antifreeze but when i got it out i checked the wreckage and wasnt to bad front bumper was a lil broke and few other small thinigs not to big of a deal tho so went to take off and made it bout 400 feet and it started beeping i looked to see what lights were going and it was the temp light and not sure what the other light is but looks like a trans light off a car so i checked my antifreeze to see if i lost it all and i wasa over heating and it was full and i checked all my other fluids they looked good so i tried to drive it to the truck and it started just fine and it made it lil bit before it started beeping again so i would shut it off and wait for a lil bit and go again after few times of that it would just start beeping soon as i started it but it made it all the way back to the truck just fine (around 8 miles) and felt like it was running souind and i grabbed rpms just fine any ideas? only thing i could thiniik is maybe the gas shorted something electical but figured it would do it everytime i started it right away even tho it started to eventaully doing it right away
If you nosed it hard enough, check near your connection between the pipe and can. You could have bent the pipe enough to burn up the lead to the water temp sensor. Not sure what else to look for, get it home and start going over things.
It's possible that you tweaked the nun, or bulkhead and pinched a hose or unpluged something.
It's the section of "frame" that the a-arms bolt to, it's removable and replacable just in front of the engine. They are pretty weak and are known for getting twisted when they take a good hard hit.
Not sure on yours though, you would have to check it out, look for things like a ski pushed back or your ski alignment to have changed.
