ok so I bought another new truck yesterday, crew cab long box. I have been researching leveling kits but I cant find a straight answer on which one to get or to even get one at all. so who has one and what kit is it? did it change the ride at all?
For leveling kits we use Traxda. Have had no problems with them. It's a key and shock spacer. The down side is to get enough preload on the bars to get close to level, the thing rides like a hay wagon. The Cognito kits that come with upper control arms I personally would avoid. We have seen several upper ball joint failures on their arms. The only way to retain factory ride is a lift that repositions the spindle rather than preloads the bar. On those IMO you maintain ride quality, but give up steering/driving quality.
I think the cognito kit is probably the best idea with the new upper control arm bent so you end up with stock amount of wheel droop. but $1200 is a little steep. I think for now I will just try cranking down on the torsion bolts 7 times. it needs to come exactly 2" to be level and I also figured on airbags with a pump so I can level it back the other way when I put 3 sleds up on the deck. I just wish I could ind a truck with the look I want and see what equipment he used and what tire and wheel size
ok I just got my truck all done. I went with a pro ryde leveling kit which raised the front 2" to level the truck. I went with 285 65 r20 BFG KO2 on 20x9 fuel wheels. the combo raised the truck 3" in the front and now I cant hardly get into the damn thing, LOL. I haven't done an alignment on it yet because I will see igf I can lower the front a 1/2" and see if it rubs or not. all in all it drives the way it did when new.
Dug back a long ways and found a pic
