I have a 11' 300xc That was a lot of fun on my Mountain horse short track last year. The bikes power is perfect for the Offroad/desert racing And it is in stock form except for the FMF silencer. My question is what add ons could I do to give it more power in the snow Yet not sacrifice it's ridability and Offroad performance in the dirt? In the snow I could always have more power
I started mixing my gas a little bit richer On the snow bike because I was worried I was pushing it too hard. Any power adder suggestions?
I just received a new 13, 300XC from a friend and customer for a build project as you are describing. He has given permission to make the project "public" as a thread for everyone to enjoy and maybe encourage others who have 250's, or 300's, 380's etc. I will start it soon.
As for power, I would recommend a fairly simple recipe.
- SX 180psi head, Slavens Racing
- mild porting, opens up and cleans ports. Strong bottom end and pulls hard all the way to the top.
- A DEP or PC pipe. More hp gains in the mid range and less fade on top.
- Red Exhaust Spring
- 250 SX CDI Box, more timing advance in the low and mid, builds power very quickly and is agressive, then a lot of over-rev on top.
- Make sure you have more than enough AIR. Any labor for air at all will greatly hurt your performance.
- 38MM Smart Carb. The APT carb nearly totally atomizes fuel. Even greater atomization than EFI . That equals more fuel surface area which gives a near total burn. Bigger "bang", more energy, better temps. That results in significant HP gains. Dyno test's on 4 stroke and 2-stroke engines resulted in an 8 - 10 % gain in HP across the board. On a 50HP bike, that is 4 to 5 HP. That is huge.
With this combo, you can accomplish a minimum of 5HP easily. That gets you pretty close to 450F numbers. Mid 50's. Don't be afraid to let her sing. The 2-stroke is designed to run WOT under a load for days. You are not even revving as high as a 450F. Your 250/300 stabilizes about 8 to 8.5K It sounds higher but is not. Your 4 stroke race motors are around 10K and rotating a cam and cycling valves at that RPM. Your 2 stroke isn't revving as high and no valve train involved. Let her rip!
