Left Handwarmer not working?
motocrazy2006
Polaris FXR 509 BCA
This week, left hand warmer quit working. Right side works and thumb warmer was hit and miss.
Right side was at the point on high could barley hold on.
Is this the relays? Or an element issue?
One relay powers both hand warmers and the thumb warmer. So it's probably an element issue. I would check the wires over carefully
to make sure something isn't shorted or become disconnected.
Check the plugins for the hand warmers and make sure they are not corroded. They are in a velcro bag down by the steering column, I have seen the moisture corrode the pins in the plug. They are different plugs for either side.
I found my wires broken off right where they connect to the heater element under the grip. Re solder them back on and all is good
