LEDs
anyone use LED headlights in a pro chassis, though I read somewhere that I wasn't a good idea, something about being hard on the regulator or something because they don't draw any power? anyone know for sure, or use them?
In terms of LED's... depends on how many watts you are planning on running... PLUS... you will need to put a rectifier in the circuit in order to make DC....
Automobile headlights run on DC.... Polaris Sled headlights on AC...with the DC side unable to make enough juice to power all but the lowest output LED's without risking damage to the ECU power side of the sled.
If you are keeping the stock headlight assembly and just running LED's in there... I think that it's not a benefit to run LED replacement bulbs...
Plus, many of them will not clear the airbox because of the big heat-sinks and fans mounted to the back of the LED bulbs.
IMO... not worth the hassle unless you have an E-start sled and don't mind re-wiring your headlight circuit and adding a load resistor.
