K
KhaosRipcord
TLDR - Has anyone delt with a leaking brake master cylinder cover after filling the reservoir? If so is there something special about the gasket/cover I might be over looking?
Long Version: When installing my 3d Logic brake lever I removed the pin and original brake lever like normal. When I did so the piston popped straight out of the brake assembly and spilled a bunch of brake fluid. I was able to re-insert it and it sealed up just fine. Brakes work like normal. However I lost enough brake fluid in the process I needed to top off the reservoir. I topped it off (per spec) and inspected everything and it all looks good. However, It now has a slow leak I believe from the cover. That is the only place I can observe fresh brake fluid emerging from. I've tried to remove and reseat the cover probably 10 times. Still has a constant slow seeping leak. And before anyone asks...yes the gasket is installed the correct way. I've inspected all parts and can't see any damage or flaws. My question is, are these reservoir cover/gaskets single use or just garbage? Is there a flaw or a trick to this I'm missing? Has anyone run across this and have an easy fix?
I did ended up ordering a new gasket and cover ($100! for a piece of plastic and rubber...thanks for nothing Polaris) and am hoping this fixes it but we'll see. If not I'll be buying a whole new reservoir for another $80..
