Kurts Polaris
B
BIGKEV
New member
Does anyone know if Kurts Kit will fit on a 15 Pro. Also im from Iowa, does anyone know if ill have a problem running his clutch kit back home if i feel like going for a ride between trips. WIll i be able to just reweight and get by? Thanks In Advance
Do a search on you tube, Kurt's / Keith Curtis (sp?) has an install video that covers your questions.
Since Polaris has not made any substantial design changes, the kit should fit the '15's just fine. From memory his helix has a low elevation track and a high elevation track so you don't need to mess with the weights, you just pull the secondary and reindex the helix.
I live in ND and don't even bother with weights, helix, and all that crap. It runs just fine with high elevation /carl's kit. My 2 cents, don't waste your time screwing with it. Just ride it as is.
