swapped starters. still has that lag.Have you done this??
Yes i agree, checked my 13 that spins fast and it was showing 70-80 but was turning over faster.60 psi is low so decompressor probably working.
Are you sure? When it does grab it spins slow? I guess you need a special ktm puller to get that free wheel off. Anyone want to rent me one? HABingo! You can see the freewheel clutch under the main gear (main gear on end of crankshaft) is turning and the crank is not or at different speed. That one way clutch is slipping. The freewheel is the larger diameter but thinner gear just behind the main gear. That clutch engages to connect starter to crank and then slips as the crank turns faster than the starter so the starter armature is not spun by the crank when the engine revs.
here is it offIt turns slow in part because it looses momentum when it slips. It will crank better with a new starter clutch.
Installed new one today and it turns over like it should. All problems gone. Thanks for your help.Hard to tell from video if you made it slip. Could take more than hand torque to make slip. Any flat spots on rollers inside the housing?
It was definitely slipping in earlier video. A new one will help the starting.
