KOSO AIR/Fuel Flashing --H on 09 M8 turbo
Mine does that too.Sometimes it doesn't come on at all,sometimes it works,sometimes I have to hit the bottom button to get it to work.It is a real piece of s*#t.The dealer that I bought it from doesn't seem to want to help me out either.What a waste of $400.00!:face-icon-small-fro
I have a on off switch wired into the power wire on mine. I usually get a error when I start the sled. Just cycle the toggle once and it resets & works fine. Shouldn't have to do that but its better than scrapping a 400.00 gauge.
Mr. Stormin do you have a power source that is 12volt? The lighting power source is 3.5-5 volts. Mine (the koso I am currently using, belonging to Bighair) did not work that a way. It did the same crappy display. What it is telling you is the unit is not getting enough power to warm up the sensor. There is a pre-wired 12 volt power source on my 07 in the steering column, or just below. It has a two wire plug with a wire loop on the end. Presto it works now! These KOSO bass turds still do not always kick on. Occasionally I still have to shut her down, and give the ol' girl another tug.
PS hope I didn't hurt those feelers
I am not sure the accessory plug is the best spot either. Rooster is using my gauge and when I had it wired into my aux. fuel pump wire it seemed to start a lot more consistently than it does for him wired into the acc. plug.
