I'm now the owner of a 2006 700 RMK 151. I'm in the process of getting everything ready to help make sure my riding season this year goes without major incident, outside of me center punching a tree. The sled has 1500 miles, an SLP can, and the fuel tank spout fix. Those are the only updates i know of.
I'm currently doing the radiator delete, and was considereing getting the kit from SLP that comes with the belly pan cover. Will this cover and one of the new bumpers from Skinz work together?
Links to said parts
Radiator Removal Kit
http://startinglineproducts.com/cat...ew=related&catalogID=3&catID=16&productID=827
Bumper
http://www.denniskirk.com/jsp/tpl/p...d=30701&skuId=516944&productId=p516944&mmyId=
Also, the intake boots behind the TBI are starting to crack. Are these a dealer only item? Where else can I purchase them?
I can see 4 engine mounts with the pipe and air boxes removed, two in front underneath the engine, two in the back on the sides. What i can see of these mounts (engine is installed) looks good, no cracking of the rubber. Is it safe to say that they're ok? Or do I really need to pull the engine to inspect the pucks, biscuits, or whatever they're called.
I've been reading, and it sounds like I need to run the 115 belt, it has the 080 currently installed (looks ok, wearing evenly so far). I read on here somewhere that shimming the primary is necessary before running the stronger kevlar belt, is this true? If so, how is that done. I understand the clutches should be aligned and belt deflection set regardless of what belt I'm running.
Thanks to everyone in advance.
Links to said parts
Bumper
