knee pad screw stripped ?
Had the same thing happen on a few of them. I pulled the stud out, heated it up with a torch just hot enough to remelt the plastic to create a new bond, reinsert stud, let cool and it's working like new.
P.S. Use the torch away from gas tank:beer;
Had problems with mine. Have used velcro (industrial strenth) no problems since. Clean surfaces first. Run in -15 degrees and they hold. Three years using this method after studs kept turning.
This was comon on 06 M7
using a screw driver Get behind the plastic so as to pry screw out as you use a drill with bit to screw out. This should pry the nut setter out. Then once out the you just need to JB weld it back in. Does this make sense?
