KLIM Edge eFire Goggle
Edge eFire Goggle​
The Edge eFire Goggle is an unparalleled companion for riders seeking top-tier performance. This frameless goggle ensures maximum field of view, distortion-free optics and relentless defogging capabilities with its hydrophobic lens coating designed to repel snow. Years of dedicated research and development have resulted in a goggle that not only provides consistent warmth and uniform heating across the lens but also minimizes snow buildup rewarding you with increased awareness and reduced fatigue.
Equipped with a cutting-edge heating system, the Edge eFire Google sets a benchmark with multi-day usage and class-leading battery life, featuring two remote-controlled mode options designed to meet the needs of the world’s most demanding riders. The magnetic quick-release mechanism, secured with a locking mechanism, effortlessly transfers power to the heated lens, ensuring an intuitive and reliable connection. The cylindrical, dual-pane lens, guarantees nearly flawless optical clarity while the multi-density frame comfortably seals out the elements while OTG-compatible frame cutouts accommodate glasses if needed. With tinted, polarized and photochromic lenses and a seamless integration with KLIM’s helmets, the Edge eFire Goggle stands out as the ultimate snow goggle with cutting-edge features ready to conquer any challenge that Mother Nature throws your way.
GOGGLE​
  • Frameless goggle with market-leading F.O.V.
  • Cutting-edge uniform heating system
  • Quick release magnetic + slide lock lens retention system
  • Frameless design reduces snow buildup
  • Outrigger frame for face sealing comfort
  • 2-part frame: Flexible inner frame for fit/seal, rigid outer frame
  • Triple-layer moisture-wicking face foam
  • Over The Glasses (OTG) compatible frame cutouts
  • Debossed nose area for sealing w/o restricting breathing
  • Perimeter frame vent foam
  • Ultra wide 50mm premium non-slip silicone lined goggle strap
  • Low profile injection molded strap/outrigger attachments
  • Custom low profile strap adjustment sliders
  • Removable magnetic latching nose guard
  • 103mm goggle height (including nose guard)
  • Includes half-cotton, half-poly goggle bag for absorbing moisture and polishing lens, pre-installed KLIM battery, battery box, lens and USB-C to USB-C charging cable (charger brick not included)
  • Spare/replacement battery sold separately
  • Bluetooth remote sold separately
  • eFire Goggle USB C 2-in-1 Extension Cable (3418-000) allows for remote storage and charging while in use sold separately
LENS​
  • Anti-scratch, quick-release, impact-rated cylindrical lens
  • KLIM’s Fluid Heat Technology provides fast, uniform heating across lens
  • Dual-pane lens with 3M™ gasket for fog prevention (polycarbonate outer, cellulose inner)
  • Thru-lens foam-filtered vent to manage temp/elevation changes and prevent fogging
  • Optically correct injection molded HD lens technology
  • Magnetic + slide lock lens retention system
  • Super anti-fog lens coating
  • UV 400 rating
  • Passes ANSI Z87.1 impact protection safety standard
  • Replacement lenses sold separately
  • Includes thermo-formed protective case with felt interior
HEAT TECHNOLOGY​
  • Water-resistant IPX4 rating
  • Up to 8 hours battery life with On Mode and 8+ hours with Auto Mode
  • Mode button: located on brain/battery pack
  • LED battery level indicator located on case/controller (Shows for 5 sec when powered on, off or when switching mode.) 50-100% is green, yellow is 20-50%, red is 0-20%
  • Mode LED indicator visible without taking off your goggles and with auto-brightness adjustment
  • Warning LED: Low battery (red blinking); improperly seated or missing lens, battery issue (red solid)
  • Hold power button for 5 seconds to turn on and off
  • Battery pack/brain mount: strap or pocket
  • Modes:
    • Auto Mode – Blue (8+ hours battery life)
      • Automatically starts heating lens when fogging is sensed
      • Blink every 8 sec (standby mode)/solid when heating
    • On Mode – Green (Up to 8 hours battery life)
    • Max Mode – Orange (Only available under On Mode)
      • 100% power for 120 sec/2 min
  • Press Power/Mode button for 2 seconds
  • Automatically switches back to On Mode
Having a battery on the side of your helmet connected to your goggles with a cord is nothing new, exciting. Clanking on your helmet, cord getting caught in branches. No thanks, had the 509's Ignite for years and have a decent list of things I did not like about that set-up.
I’m curious about the battery life in cold “-20 to -30F)
The remote cord needs a coiled section for stretch.
My CKX 210’s work great but they can eat a battery in 2 hours.
Looks pretty sweet
the cable they show in that photo is NOT what they are actually offering as the Acessory cable.
The final one DOES have a COILED section.
I am trying to pull what few strings I have to get my hands on a pair of these before the official release date of October 8th.
Either way, I will buy a pair at the first opportunity and then get them on here for a real hands on review.
Hopefully the battery claim is real.
My CKX battery lasts 10 hours if it’s 20*F.
It’s 4x the size of that klim one.
Agreed.
There are Several Features on these that "Look" like they will beat my current 509 Ignites.
Auxiliary External Power
Remote Power Control
MUCH Beefier power cable connector with a Band Stabilizer.
I want to ask the powers that be WHY they chose NO internal Fans??
Fans don’t work.
It brings in cold air which freezes humidity.
Plus it dries your eyeballs.
My CKX goggles get warm enough i feel it on my face. (It keeps my glasses defogged)
509 ignites do nothing for my glasses.
Get the Tempest and be done with all the batteries strapped to helmet, mode settings. Put them on and forget about it. No battery issues either
