King Cat Carbs
Decided to bring this thread back up rather than open yet another thread on kk jetting.
I have an 05 kk, I have problems getting my sled to come back down to an idle after a couple good pulls, once it gets back down to normal idle it stays there until I go wot again. I am currently running 400 mains with 55 pilots and have the foam out of the air box with the baffles still in. I also have a mbrp can. I recently put new crank seals in the sled, but had this problem since before that. My previous jetting was stock 360 mains with 50 pilots and the same issue. I also have the low speed blubber but not to worried about it as it cleans out pretty quick. I always have left the coolant flow open through the carbs.
Any suggestions would be appreciated thanks.
I do have an 05 kk and yes it does have carbs, last year available with carbs. 06 came with efi only!
I have never seen a kk with (cabs) though either lol.
King Kat Idle
About 2 years ago there was a great post on high idle problems with rack mounted mikuni flat slides. Good idle and coming back to an idle has been an issue with that mikuni carb design since day one and worse on some of the Polaris's.
After lots of testing an aftermarket Polaris shop determined that ( not sure I remember this exactly ) air leaking around the slides is a big issue, so loose top screw / poor carb top gasket.........and when the slides wear a little they just get worse and worse, and just general overall poor fit and finish on some of the runs of new carbs makes some sleds worse than others. So air leaks around the throttle shaft ( same as a holley carb ), and a wearing out throttle shaft or a loose shaft when new........bad idle or idle down problems.
so..........won't come back to idle, its lean, but when you pop in the big pilot its comes and goes and blubbers, carb problem, ok carb design problem.
Might find a post on this on the Polaris forum.
King Kat Idle
I have this problem also, usually when stopping on the trail.
I either give it some throttle or choke it and it comes down.
