Doesn't it only sense barometric pressure??? .....so a combination of temp and altitude...air density?
It shouldn't know whether it's 50* at 4,000ft or 30* 6,000ft....both would have a similar air density. a 20 degree change in temp is similar to a 2,000ft change in altitude. Seems to me, if it was from temperature then they would see the same issue at higher altitudes even when it's cold. ????
They run fine at the grass drags when it's 90. ??
Everything on this sled is stock. Nothing has been changed other than 58 gram clutch weights.
58's? Really? I was in WA last week on two decent '11s and they lost 3-400rpms
In tanning temps. RPMs came back the next day when it was cooler.
If the engine load is too light, dumb things can happen. YMMV.
Yes 58s. We unload @ almost 11k. Probably some of the highest riding in the US other than ak....lighter sound.
Do you have a set of 56 gram weights? That's what I ran in mine there before my BoonDocker turbo. With the track you had on and how heavy the snow was, I'm surprised you were able to get over 7600 rpm.
Matt, i hope you checked this guys primary spring... bog off bottom screams on top, sounds exactly like a broken primary spring...
(how many of those were replaced this year?? exactly...)
We sold about 25 to the local folks around here.
Did you see any bogging issues?? If so what's going on? My dealer seems to have few at this point and he seems to think fuel pump. I think more is known here after going to snowmobile show and asking a bunch of questions, but everyone seems very vague. I think they know the problem but Polaris has no parts. I want a solution before the factory warranty runs out and I'm dealing with a secondary company.
