Killing the nun
Started looking at these posts about the XP's checked mine and my LH spring is only 1/4" from the A arm. Can't see anything bent, and the only time I remember hitting anything hard with that ski it wasn't too bad.
Is it fair to say if you get the new center piece it is just a bolt in deal (after you grind/cut the old rivets out) and everything should line up again?
Your cast center piece is slightly twisted in the nun. the front bolts of the lower arms twist and stretch the metal, then your bolt wholes don't line up.... have to order the whole nun assemblly, (s-module) done mine once, and have to do it again (have another one on order), i can take pictures to explain what i'm talking about, i couldn't see anything bent either, untill it was takin apart and sitting on the bench. i grinded all the aluminum bolts and rivits out replaced with SS button top bolts.
Now that i have to do this all over again, i ordered and bunch of braces from rip and grip racing.
mike
