I have been struggling to make my 21 165 Khaos ride as smooth as my 19 174 RMK. It takes big hits just fine but the small chatter bumps transfer to the rider. I am also finding that the Velocity shocks seem to have very little rebound dampening as it bounces off bumps and can put the rider out of control. I am wondering if this valving is designed to quickly lift the sled after a compression to give it "Instantaneous Lift"?
I have tried the low and high speed dampening adjustments from one end to the other and have found the best I can get it it to have the high speed a bit stiffer than stock while having the low speed a bit softer than stock. Ski shock springs and rear are set soft while the center shock spring is turned up 2 turns to keep the front end light.
I'm sure there are guys who will just say "get them re-valved" but it is not easy in Western Canada and is expensive. I'm also not convinced that a shock tuner would 100% get it right the first time around.
Has anyone found other settings on the factory valving and springs that seem to work?
