We have khaos length limiters that come with our conversion packages. Please call the shop and we can get you taken care of.
406-763-0365
Messure shock shaft full extended
without limiter stripes
Make new holes in strap so shock is 3-5mm shorter than full extended lenght.
What does this accomplish?If you are installing Khaos rails on a Pro. Use your stock PRO shock and stock limiter strap. You will like it, I’ve converted a number this winter.
The khaos strap will let the shock out about 1/2", so it is not compatible with a Pro length FTS.
Measured my Khaos this morning, looks to be 19.5 cm. Used same points as you used in your picture.View attachment 344742
It’s in between, a little more on the Khaos side I’d say.What does this accomplish?
less planted feel or...
Somewhere between a pro and full khaos I’d guess.
Am Debating doing raptor limiter and shock extension or do rails get it done without?
Yes, it works very well.You've been installing just the Khaos rails and everything else stock for a pro?
You will use your stock PRO shock and PRO stock limiter strap with IceAge Khaos rails.Did you install a shorter RMK limiter strap?
Yes it works great with an anti stab.Anyone have any results going the other way? Mine is a 174 so khaos rails aren’t an option, but I thought about the longer limiter strap and velocity shocks off a khaos?
