Keeps fowling pto plug! HELP
what is the compression on that side.
also maybe you have an electrical issue and it is not firing that plug causing it to fowl
Well i sure hope its a dirty carb? could that be it? I just sold the sled to a friend ad now he is having problems and its his first sled so now i get to work on it. woo. If its electrical where should i start?
Thanks!
The first place I would look at is the choke/choke cable. If the choke is open even a tiny bit it will run rich. A 12 mm. wrench and you can remove the choke on that carb and shoot some carb cleaner down in there. Then make sure it is moving when you pull the choke lever. Reinstall and maybe even loosen the cable a hair to make sure the choke is seating. A little easier than tearing the carb off. It may still be needed to clean the carbs completely but a little easier place to start.
