keeps breaking tracks
I have a 2005 king cat modded big bore kit etc. hp. rating about 245. 2 out of the las three rides I have blown the trac, sheered it off like it was cut in 2 any one have an idea as to why this might have just started happening i we had track totally lined up and adjusted proper and suspension components all looked good and moved fine this is getting very expensive Not lol. the last track was a 2010 pro claw or something like that it was a take off from a 2010 cat dont know which one tho:face-icon-small-fro:face-icon-small-fro:face-icon-small-fro:face-icon-small-fro:brokenheart::brokenheart::brokenheart:
Are you running a anti stab kit? If not you should be, that may fix your problem. For some reason the king skid was known for stabbing tracks.
I've put those rails in a 50t press and gently, with heat, tipped the rails up another 5 degrees or so otherwise with big ponies all you have is pitchfork..maybe bring some olives. I x2 what rixster said get some anti-stab kit or tip up the rails.
Yes, when you stab a track it will usually look like it was sliced in 2 pieces nice and clean. You MUST have the anti-stabs on the rail tips for 3.0" pitch tracks. I recommend them on ALL applications. Cheap insurance.....and make sure to loctite the pieces together when installing.
