I would presume that you have done the clutch wieghts in the primary already, because this is the leading cause of rpm flucation, usually not enough pin weight. Had a gentleman come and ask if i had some some weights for the primary when i was in McCall Id. because he was was having the same problem, just happens i take my clutch tuning kit on sled trips, sold him some weights and later he had told it was much better, but could stilll use more.
Well I have the same helix as you and run 16 grams, 160/350, 20/49 on a 163 from 3-7k. I don't lose any rpm climbing, clutching is nuts on.
