The new beehive almond spring they are using is engaging around 4300rpm + for me. I'm using the SSI weights instead of the Venom weights that came with it. Stock helix 40deg.
Which springs and helix are you running?
What weights?
Im running the pink primary spring with dalton adjustable weights and the helix that came with the kit.
Ok, this seasons kit has different springs. The pink is way to stiff, you would like t much better with a Almond/Red spring and also you could run less weight with it. Also a Black/White or Black/Silver secondary.
Your local Polaris dealer should have these in stock.
You running the 42/44 helix angle?
Not an axys, but I went down in primary spring engagement because engagement was too high for me and my riding style, too much spin out of the whole, hitting too hard at the start.. wanted a more progressive engagement. I'm sitting around 3900-4000 now on a newer belt with proper deflection
My silber axys turbo has a really jerky clutch engagement just doesnt seem to be right. Is anyone else having this issue?? Otherwise its a great kit no complaints. I dont know if the guy that installed my kit didnt install the clutching properly.
