Oh, and just so you know I’m using the original ’2010 update (which I believe was the Aug. 09 version) and a PC5. After 3 (or is that 4?) years now, my sled still runs solid. It’s a dam good sled and I have no plans of replacing it anytime soon.
FYI:
The 800 has 3 injector colors (dots located on body of each injector) - Blue, red, Yellow. All injectors should be of the same color.
The 04-15-10 flash number = Blue 4013135 , Red 4013134 , Yellow 4013136
The 01-11-10 flash number = Blue 4013066 , Red 4013065 , Yellow 4013067
Original 2010 update flash = Blue 4012959 , Red 4012958 , Yellow 4012960
You can have your dealer run a "Service Report" and it will list the "Software part #". That will tell you what you have loaded.
ok looks like I can access the map database on my version.. As far as I can tell here are the orignal 2008/2009 ecu software numbers.
red = 4012705
blue = 4012706
yellow = 4012707
UPDATE: Looks like I do have the correct numbers for the 2008 D8 - They are the same as the original 2009. there were no updates from 2008 to early 2009.
FYI: Here the numbers for the NON US/CANADA editions (says here 08/09):
red= 4012730
blue= 4012731
yellow= 4012732
