So after a couple of post regarding to the bearing problem on the jackshaft I wanted to see if my jackshaft was starting to lose material. I took it apart and it looked good exept it had alot of oil/grease where it sits in the bearing. And was wondering if it is oil from the bearing (from high temp) or do they assemble it with grease?
The bearing it selfe had alot of drag in it, and I could see the shaft spin inside the bearing. So i guess this is what causing all the heat
