So, not the start to the season I wanted. I finally got out riding recently, and everything seemed normal. The first indication of trouble was after about five miles trail riding in and six to eight miles of playing around. It was a little hard to start, and didn't idle quite right, but didn't seem like anything major. A bit later, in a climb, it started cutting in and out if I went wide open - not like dying completely, more like I was dropping back to half throttle, and back in. I thought maybe it had something to do with the gas, so I switched to eth mode, but it only got worse, so we limped back in. Never a code or strange noise - about the only thing I noticed earlier on was it would hesitate just a half second from a dead stop, but it's done that occasionally as long as I've had it.
I got it home and took the plugs and exhaust valves out. The PTO side was sticky, and when I got a light in the port, I could see damage to the piston. So I continued far enough to get the head off, and sure enough, I've got a busted up piston, and worse yet, the bore has chunks broken out of it, I think all around the exhaust port. But the biggest chunk of broken piston is on the opposite side; I suppose one caused the other. It doesn't look like oil starvation or a lean condition - other than the obvious damage, the piston looks much the same as the other. I keep a pretty close eye on oil consumption, and it seems to have been feeding right. One other interesting thing is that there's not a mark on the head stuffer; I was expecting to see it all pock-marked from chunks of aluminum flying around.
Some history: it's got an Indy Specialties long block. 2012 Pro RMK, 163, all the upgrades you'd want for durability (like an extra cooler, Doo thermostat). I'm not sure how many miles, but I think around 1500 miles on the motor. It's always run well, other than being a little hard starting. I've never put anything but ethanol-free premium in it. For better or worse, what I've been doing in the off-season is storing it full with Sta-Bil, and started it up now and then over the summer. I won't call it ideal, but it didn't seem to be a problem in a couple years with this sled, or with the old 600.
So, what caused it, and what's the best solution? I want to fix it right, but at the same time I'm not in the best position to be dumping a couple thousand into it. I also wonder if there's something I need to be fixing beyond the mechanical damage, or if it looks like a locating pin failure or such. Of course, it has to happen at the absolute worst time to get anything fixed on a snowmobile. At least I can handle tearing it down and all. Just not where I wanted to start the season; I guess the old 600 is going to get some action again.
![IMG_20230105_224407.jpg IMG_20230105_224407.jpg](https://www.snowest.com/forum/data/attachments/342/342626-87ded67cf813d9432f8830de08eb8a6d.jpg)
![IMG_20230105_224729.jpg IMG_20230105_224729.jpg](https://www.snowest.com/forum/data/attachments/342/342624-10e6c28fe883894033526e342894977b.jpg)
![IMG_20230105_224433.jpg IMG_20230105_224433.jpg](https://www.snowest.com/forum/data/attachments/342/342625-18fd02bba08be2d6ef0dfdeea1650a0e.jpg)
