Some of you guys go crazy on those carbides! I just take a dremel tool, ramp both ends and take the sharp edge off the top. Takes less than 5 minutes, makes them a lot less grabby and doesn't cut up the trailer runners.
X2 ullose, I myself no longer run a carbide but instead run a single piece of Ti. 3/8 rod. Lightweight and doesn't catch or snag anything.
It doesn't mean your a-arms on your axys are going to bend on the first ski-tug...
A sleddder who just couldn't wait for enough snow, just has to get the first ride in, hits a rock and $500 in damages happen.
This thread has determined
1. We need to carry spare a-arms in our backpacks
2. As long as there is snow, there are no rocks therefore no damage should occur.
3. Glued metal sucks but in tests, the metal breaks not the glued joint.
4. Polaris designed the a arm to bend instead of the bulkhead.
5. Axys owners should order 8 sets of a arms because of a looming shortage of epidemic proportions and all sledding will cease immediately.
6. If one doesn't bend an a arm in 3 years and 5000 miles, then it stands to reason he never will and any damage is the someone else's fault.
Never had an issue with the glue. I think it is innovation in other industries that led us to glue on our sleds. Obviously you didnt see the pull test samples polaris carries around. The alumimum pulled a part not the glued joint. Im not worried abiut the a arms until I ride the sled and see.
