Hello everyone.
Seeking some advice/opinions on some strange issues that have came up on my 08 nytro mtx.
I bought this machine new at the end of 08 and have had virtually no problems up until several weeks ago.
Sled is basically stock (different handlebars and 09 subframe) with under 3000km (1800miles).
Recently got error code 84 (TORS throttle overide sensor). I inspected my throttle cable down to the throttle body and did not find anything wrong. I recently put a new bar and riser on and was hoping that was why the TORS was acting up. It only acted up with a rough idle after sled was warm and I was idling. I remedied this by disconnecting the TORS as learned on snowest.
Next day of riding the error code and annoying orange blinking light was gone. Problem solved I had hoped.
I then noticed an odd popping or like a drum like sound that sounds like its coming from my exhaust particularly around 5000-6000rpm. Its less noticeable when on the gas above 6000. Its usually 3-4 "thum thum thum" almost like its missing although the engine doesn't seem to hesitate.
Its not affecting the performance as far as I can tell but Im sure the noise wasn't there before.
I thought it might be water in the fuel system and used a "seafoam" product to try and remedy. The noise is still there.
I also discovered that when the machine is idling and I tip it over at about a 45' angle to the left the idle drops significantly and runs very rough. doesn't affect it when tipping to the right???
I appreciate any comments or opinions on the potential problem.
Thanks in advance!
Thanks in advance!
