Is this possible?
Can you fit 2 sleds in a 6X12'' enclosed trailer..? i know it would be a squeeze if its possible.. but has anyone done this? possible with 1 fwd and 1 facing backwards?
Thanks.
U thinking Uhaul? I put a 162 M7 is one once. Was doing a dealer transfer and had another sled in the box. Only way to do the trip within the timeframe I had. I had it in on an angle although I was hoping not to. The insides of those trailers aren't really 6x12 if that's what you're thinking. I ended up measuring it but I can't remember what I came up with.
buddy of mine has a 6X 12 that is actually 6X12 and i have to pick up two sleds from a dealer which is quite a treck away.. so i was hoping someone had done this.. i could rent a bigger trailer but it would be super helpful if this is possible. So was that a yes you fit two in a 6X12? or was that 1 m7162 only?
That was a negative. One M7 162 without skis had to be put in on an angle.(It's an enclosed though, so the door had to be closed which takes away space too) But like I said, it was a UHaul 6x12 which, like I said, definately not worthwhile to even try. But an open 6x12 that you can hang the sleds off of(to a point of course) shouldn't be an issue. I don't think you'd have an issue.
any reason you have to get an enclosed? There's a place out here that rents two-place tiltbed trailers for $30/day...
id prefer enclosed b/c theyre brand new sleds... doesnt matter much but its a 10 hr drive. ropads will be nasty and salted. would prefer to have em sheltered for that long of a treck
How about, first sled is pulled in backwards right to the front wall of trailer, set of jackstands under the skis to get it up. Push other sled in backwards untill back of seat is touching track on the first sled.
Good luck.
