Had my 2013 pro 800 in for a electrical problem and they did a compression test on it ? The problem was the throttle safety switch! Any ways the sled has 900 miles and came out 120 MAG and PTO is this good? Thanks
I had 119 and 120 when mine burned down. they said oil line came un donebut I think piston skirt broke and caused whole engine to be destroyed.1484 miles on 12 800 pro
When I sold my 1999 XC 700 it had 17,000 miles on it. I had 118 lbs on one cylinder and 120 on the other, never had any work done on the motor. I have always been told as long as both cylinders are close to the same with in reason you are good to go.
$.02
Mine are both the same but I have horrific top end bog
But this has nothing to do with compression right? That can be very confusing for this thread.
