Is there a way to read the flash codes from the sled?
E
e46m3
New member
During a ride yesterday, the check engine light start flashing. When I stopped and let the sled idle, the light stopped flashing. Then after riding for about 5 minutes the light started flashing again. I did not count the flashes. I there a way to read out the flash codes from the sled without riding it and trying to count flashes while riding? Thank you.
You can try and run it on a stand and get the code to come up, or take it to Polaris, they can hook up and see the stored codes I think... don't quote me on that.
Rode it around until the light came on. Counted 5 flashed. That is a exhaust temp probe fault. Checked the wires for the sensor and they look fine. I am running pre-mixed gas plus the oiler is set rich as I am breaking in a new top end. Leaving for steamboat on sat. Thinking the sensor is covered with oil from the pre-mix fuel and rich oiler. I might just bite the bullet and buy a new probe in case its not the oil. I dont want to get out there and have it run like ***. Thanks for the info guys.
