Is it worth the trouble?
skotertoken
Hi!
I'm about to get a turbo for my PRO-RMK and wonder, have the previus kits bin running fine? Is there much trouble? I have built and owned a mean nytro MCX turbo, and looking to hear the difference. I'm thinking about the BD kits mostly but want to hear from you all!
Thanks/ Jonathan in Sweden
i have over 5 thousand miles on mine and love it... i've had a few little issues along the way but its been hands down my most reliable sled i have ever owned and i run 12-14lbs of boost day in and day out
No one that builds turbos has the new CFi system yet on their shop floor to work with it.
The hardware and plumbing portion of it should be easy... Fuel management and integration will be the big challenge.
I really doubt that ANY will be on the snow this season... Struthers/BD would be my best bet for first out with one.
Supplemental fueling with only 2 injectors will, IMO, be a challenge that needs additional injectors and a way to mount them.
I am on my 3rd set, have never had any issues just replaced them for preventative maintanence
pretty sure most have that figured out already after playing with the dual injectior bodies on the cats so far... but it all takes time to get it locked down and ready to sell to the public.. im excited to see the new chassis under boost.!!
Do you run it on pure race gas or 50/50? My challenge will be that I will build it for pump gas only. The race gas cost 23,69usd per gallon in sweden... Not so funny! So I will build it for 98octane, so is here anyone out there that have their sled setup for pump gas? And how much boost are you running?
With low comp head im going to run 0,7-1,0 BAR of boost at 2000ft. currelty running 0,4 BAR of boost with standard head at 2000ft. All on Swe 98 oct fuel.
How does the turbos work at "touring" driving? Do you have to be on your toes to avoid engine damages or does it work well?
I Live in Mora. Well with the current map for all Scandinavian 800CFI's it was a bit hard to get the "cruise" mode to be good. But it works quite well, ofc you have to check your gauges from time to time. Ill still finetuning the sled. but so far it works good.
BD är nog rätt kitt. Angående laddtryck så kan du köra Silbers water/metanol injecton så kan du ladda som om du kör på 116 oct.
De är iallafall de som kommer på min 2011 RMK Assault.
ill be running Silber kit on my 2011 assault with low comp billethead and aprox 0.8-1.0bar of boost. The BD kits are almost twice the money vs Silber and the silber kit works like a charm so im not going to change =)
I have decided to run Silber kit with my own ideas applied. :) I also made a change on my order to a RMK assault! That sled is the most complete sled I ever rode, rock and roll right out the box! I also found the assault easier and more reliable in boondocking.
